VERY LARGE VFD DISPLAY TUBE ILC1-1/7 clock nixie 4 pcs
Found on eBay / Starting bid $135 / 4pcs
Large Single Digit VFD Panel
I found these large flat VFD tubes on eBay and this appears to be the second or third set from this seller.  They are apparently NOS and could make a killer clock.  Not one you would want to keep in your bedroom, but it would be distinctive.  These DO have a filament so multiplexing these would be possible.  As far as the seller goes, I have purchased several tubes from Urals and had great service every time.  I don't know him personally but I wouldn't hesitate to order these...if I had a use for them!
From the auction
Very large VFD display tube ILC1-1/7.
Lot of 4.
This never been used, from the old stock.  Indicator displays one digit.
Size 83mm x 140mm. Size sign 46mm x 85mm. Color green.
Parameter
ILC1-1/7
number of segments in sign
7
filament, consumption of current (nominal), mA
120-220
rated (nominal) voltage of filament, U
4.2-5.5
rated current of grid , mA
35-80
Constancy summary current anodes-segments, mA
70-100
rated (nominal) voltage of anodes-segments and grid, U
22-24
brightness , kd/m
600
