by Dieter Wächter / Nocrotec
$375 - $399
This device easily is one of the most attractive tube clocks for sale. Dieter clearly has a talent for not only the engineering perspective, but also for the aesthetics. Sadly, this clock is no longer for sale on his website or thought his eBay account. This clock comes in two variations: with rounded tubes and with flat top tubes. The flat top tubes are DA/DR 2000 tubes while the rounded ones are DA/DR 2010 tubes. DA = Apollo. D = RCA.
More photos links after the jump
FTA:
Features
- 12/24h mode
- Alarm clock
- Power Down Mode: tubes and supply can be totally switched off for a user programmed period in order to save energy and increase life expectancy of the tubes
- Numiclock x2000 information: http://www.tube-tester.com/sites/nixie/different/x2000/x2000.htm
- Tube-Tester: http://www.tube-tester.com
- Nocrotec: http://www.Nocrotec.com
- Nocrotec eBay: http://shop.ebay.com/syntax-error-64
