By Jeff Thomas / Resonant Instruments LLC
Kit w/o Tubes $299
Assembled w/o Tubes $349
http://www.amug.org/~jthomas/nixichron.html
This is my clock. I am the proud owner of the last one made according to the creator himself. The display in this clock is a Russian Nixie tube called an IN-18 / ИН-18. This is a really odd display. There are 10 filaments inside of the tube. Each one is shaped in the form of a number. The tube is then filled with neon gas and a little bit of mercury to prevent cathode poisoning. When ~180vdc is applied to one of the numbers, it glows.
Six of the IN-18 / ИН-18 tubes are used to display the time. Like the Scope Clock, the time is set via GPS but a built in clock keeps the clock going when a signal cannot be located. The tubes are some of the largest that were produced in quantity which adds a collector value to the clock. Since they do wear out, I have a second set stored in a hard Pelican case.
Update:
As of 7/22/2009, the clock is once again for sale. It is now being offered fully assembled for $349 or as a kit for $299. If you're looking for an IN-18 clock, this is the one to get! http://www.amug.org/~jthomas/nixikit.html
Thanks to Michael for the update!
Build suggestion: Use a bright white LED for the 1 pps LED and add 2" leads to it. Then aim the LED at the base of the 1 second Nixi tube hole in the circuit board so that it shines into the glass nipple at the base of the Nixi tube. It's not too bright, but it does look very nice, and it allows you to easily see the 1 pps pulse just by looking at the base of the tube. This clock is awesome.
Just note to ask you for your email address, as I am interested to order the nixie clock from you. I do have a query in regards to nixie tubes and your advice to interfacing it with oscillator. looking to hearing from you, teng-lam
