Claus-Dieter sent me information on a new product that he built along with Dieter Wächter of Nocrotec.com fame. This new gadget is is a two digit thermometer based on IN-16 Russian Nixie tubes. The tubes are lit from underneath with a blue LED and there is a neon lamp that acts as a negative sign indicator. The temperature sensor is a Dallas DS18S20 on 1, 2, 5, and 10 meter lengths. This device supports up to two sensors so you can have the device can report both indoor and outside temperature.
The clock has a nice small design with all of the components hidden on the underside of the board. The clock enclosure is up to the user to design.
The software has a few neat features too. It has a smart menu system that makes operation easy. The user can adjust the update frequency and error detection settings. Additionally, the device has a built in cathode poisoning prevention mechanism; the device cycles through digits in a simulated slot machine effect to prolong the life of the IN-16s.
Features
Input voltage from 10 - 14 Volt DC
Low current consumption is 150 mA
Standard power adapter for worldwide use available
very high efficiency by using modern switching power supply technology
switchable floor lighting
pcb illumination by LED light (can be switched off)
easy to build
no smd parts
sophisticated software with user menu
Cross fading selectable in 5 different levels or to be switched off
Cathode poisoning prevention
Up to 2 temperature sensors connectible
"minus sign tube"
easy to build
no smd parts
minus sign tube"
"minus sign tube" can also be replaced by left decimal dot
Error detection for faulty temperature sensor or faulty signal
small, compact circuit board
Simple 2-button operation
including mounting spacers
alternating cycle between inside and outside temperature selectable
All settings are stored in case of power failureno adjustment necessary
measuring range from -55°C to +85°C / -67°F to +99°F
Display in ° C or ° F
Long cables available for external sensor up to 10 m
Pre-assembled temperature sensor cable available from web shop
Specifications:
Minimum input voltage: 10 V
Nominal input voltage: 12 V
Maximum input voltage: 14 V
Maximum input current at 12 V: 150 mA
Maximum input power at 12V: 1.8 W
Measuring range: -55 ° C to +99 ° C
Range: - 67 ° F to +99 ° F
Tolerance: ± 0.5 ° C in the range of -10 ° C to +85 ° C
Overall width module: 97 mm
Total depth Module: 67 mm
Total height module: 65 mm
