Collins Nixie Tube Counter
From The Auction
Up for auction is a working NASA Nixie Tube Clock Time Counter Display with 8 Burroughs model B-5441 nixie tubes. Check out the pics this time code counter is still working good. It was owned and used by NASA and it was made by IRA systems and it says Reversible Time Clock model 748 on the front. We've also taken pics of the inside to show that it's in great condition. This is a 19 inch rackmount version. The only problem is the cord was cut but we rigged it back up with tape. You might want to re-solder a new cord. If you don't know how to solder we will do it for you for an extra $20 charge. This item was acquired from a NASA museum. Check out the pics!
JSN Boot template designed by
