Here is a great series of clocks by This e-mail address is being protected from spambots. You need JavaScript enabled to view it from Germany. Electronically, they are based off of Jürgen's designs but Heiko elaborated on the design and sells them directly via his eBay store. Be sure to check out his different designs below; they all share a common feature set.
199 EUR
Nixie CLock Gracia: Type of tubes: LC513..Digits height: 15,5 mm..LED back light with fixed or slow changing color..Enclosure size: 170 x 90 x 58 mm..veneered walnut enclosure (can also made from oak or cherry) with brassiness decoration rings around the tubes and engraved type l
179 EUR
Nixie Clock Catalina: Type of tubes: IN-8..Digits height: 18mm..No LED back light and aluminum decoration rings around the tubes..Enclosure size: 200 x 63 x 25 mm..Di bond stainless steel optic with black Röhm Plexiglas top face
189 EUR
Nixie Clock Sharonna: Type of tubes: IN-8..Digits height: 18mm..No LED back light and brassiness decoration rings around the tubes..Enclosure size: 200 x 63 x 25 mm..veneered walnut enclosure (can also made from oak or cherry)
429 EUR
Nixie Clock Claire: Type of tubes: Z5660..Digits height: 30mm..Neon colon separators, no LED back light..Enclosure size: 240 x 75 x 25 mm..Di bond stainless steel optic with black Röhm Plexiglas top face
