Wemos Nixie Clock Support Forum
6 digit numitron - flash another wemos SPIFF5
Thank you received: 0
1 year 8 months ago #11888
by ROBERT
Hi, I wanted to flash a new wemos from the .bin file you provide, but after that at startup there is the error message SPIFFF5. Spiff files are not include in the .bin file ?
Thank you received: 201
1 year 8 months ago #11890
by ROBERT
Many thanks for your reply. Yes I've read this thread, I use 2 methods :
1- from the windows console :
esptool -vv -cd nodemcu -cb 921600 -cp COM3 -ca 0x0 -cz 0x400000 -ca 0x00000 -cf DA2000-V6-6digit.bin
2- from ESPEasyFlasher
Each time the transfer looks good. And in fact the wemos well starts, as it can display the message SPIFF5 before counting from 0 to 9 infinitely. It can keep past wifi setup, and the IP address is seen on the network, therefor I cannot connect to the wemos.
1 year 8 months ago #11891
Are you sure that SPIFF5 message is really an error? Mine displays that message during a normal start-up. It goes: STArT_ SPIFF5 nEt_UP ntP_UP and then rtC_UP (I think, that last one is real fast).
If the clock is not yet set up on the network, instead of nEt_UP you get an error and one tube is back-lit with blue. That means the Wenms is being an access point (not a station) and you have to connect to it and give it the credentials for your WiFi. See page 14 of the user manual.
www.nixieclock.biz/Downloads/DA2000-Clock-User-Manual-V5.pdf The user manual says the clock's SSID is "ESPClock" but I think it is actually "VFDClock", It should be easy enough to figure out since it's likely the only network that will show up with Clock in its name!
1 year 8 months ago #11892
Actually I just did a full reset on mine and the configuration SSID was "esp_0a4d1f". Everything after the "_" will be different for yours because that part is gotten from the ESPs MAC address.
Ian
1 year 8 months ago #11893
by ROBERT
you're right !!!!
I forgot the push button, I added and press it, then it entered in AP mode.
Many thanks !
Time to create page: 0.092 seconds
