MikeS wrote:
Ian wrote: I have just put together what I think is the last firmware changes...
I'm amused.
Good point.
However, we're only talking about V0001 here, so I'm not saying it's finished.
It took me
ages to get it right. I've been fiddling about with it for at least two months, but now I am happy with it for a release. It's tricky to get the ESP8266 just right to run a multiplexed clock, WiFi and NTP all without them interfering with each other. The ESP has to balance its time between the display (which is highly sensitive to disturbance - the slightest hiccup is visible) and managing the rest of the work that has to be done.
To get this right, I went through these iterations on the net management:
1) Time server using a synchronous HTTP client: Response is too slow and causes the display to blank for 200mS. I also want to get away from the proprietary server solution
2) Time Server using an asynchronous HTTP client: Better but still visible
3) ezTime: Better but uses synchronous UDP and still visible. I also found that ezTime makes a real dog's dinner of the time zone handling. Much too complicated.
4) NTP using ESP SDK: Nearly right, but uses synchronous UDP and does not allow the update interval to be managed
5) NTP using asynchronous UDP and C time management. Yaay! Fast, flexible, configurable, no display flicker.
The clock uses NTP while it can, then if that becomes unavailable, falls back to RTC, and if that is broken or unavailable, falls back to internal time management using millis(). Each type of time source updates the ones further down the stack, so if we get and NTP update, it sets the RTC and the internal time source. When NTP is not available, RTC updates the internal time. Reconnection also works great.
