Builders Forum
Wlan connection problem
Thank you received: 4
4 weeks 49 minutes ago - 3 weeks 6 days ago #13185
by Joker
Hy,
I am surprised myself why I have so many problems or questions - I hope you can forgive me for this.
My clock is running now, but I can't get the wifi to work.
I am using the Classic Rev6 board with ESP01S module. I have specified this in the Define of wifitimeproviderESP8266.
My problem is, the module starts and everything runs stable. After I have entered the wifi access data in the wifi manager, the ESP-3369CC device appears briefly among the connected devices and then disappears again and I see the nixie wifi again.
I have changed the Define to ESP01S.
I have used all the library states as in the source code. I have updated the Wifi Manager to 0.16 - but without success
Does anyone have an idea what the problem is or does anyone have the same problem?
Last edit: 3 weeks 6 days ago by
Joker.
Thank you received: 0
3 weeks 6 days ago #13187
by mj666
Be sure to use libraries an board definitions like specified in the source code. I have seen issues like this with latest version of the board definitions. You likely need to downgrade to an older revision.
Thank you received: 201
3 weeks 6 days ago #13192
Don't overlook the Board Definitions, which are not included in that Bitbucket repo. You should be able to just use Board Manager in the Arduino IDE to fetch and install the correct (and probably old) board definition.
Joker
2 weeks 5 hours ago #13217
by Joker
I think the board definion was the problem. I installed the old one. After this, it works flawlessly.
Thanks for your help
1 week 5 days ago #13223
And that is the problem with the Arduino "universe" - there's little to no control over revisions to board definitions and libraries and such. Updates with breaking changes get released with little or no warning. It doesn't undo the good aspects of Arduino but it sure can be troublesome. Arduino could take a good lesson from the maintainers of the Perl modules repository, who are almost obsessive about compatibility testing and hardly ever let a broken module to be released. But that's a huge amount of work!
Builders Forum
Time to create page: 0.100 seconds
