Builders Forum
New router - can't connect numitron clock
Thank you received: 0
1 month 2 days ago #13174
by Xntrix
Hi, I have 3 numitron clocks, all have been running faultlessly. I was recently sent a new router by Plusnet, and now I can't seem to connect at all! Firmware is V6. Please tell me i'm doing something stupid! Cheers, David
Thank you received: 201
1 month 2 days ago #13175
What are the clocks doing? Are they getting stuck with one of the under-tube LEDs showing blue and going into Access Point mode?
Is the new router's SSID (network name) and password the same as the old one?
Are you sure that DHCP is turned on in the new router? I would think it would be on by default but you never know.
1 month 1 day ago #13176
by Xntrix
Thanks for your reply. I have factory reset one clock. Network and password are different on the new router. The clock shows up in my "available networks" as ESP_216397 - I can't connect to it.
Upon power on, clock does the following:
led led led led - hour & minute led's
Green Green Red - tubes: Net_up
Green Green Blue AP--On (long pause)
Green Green Red Red - ntp up
displays Version - 6
starts counting
I am afraid I don't know how to tell if DHCP is on or off - I have looked at the router settings and don't see any mention of it.
David
1 month 1 day ago - 1 month 1 day ago #13177
Ok, so the clock is in Access Point mode. Makes sense since the router's SSID and password are not the same as on the old one. DHCP is not of any interest at this point.
This sounds a lot like what was going on in your
old thread
from a couple years ago. Have you tried the things that were brought up in that thread & eventually lead to success?
EDIT: Specifically this:
www.tubeclockdb.com/forum/4-builders-for...clocks?start=0#11021
4 weeks 2 days ago #13178
by Xntrix
Hi, thanks for all your help - and your patience with an old fool. Clocks now connected again!
Builders Forum
Time to create page: 0.095 seconds
