Builders Forum
Resistors for INS1
Resistors for INS1
Thank you received: 4
1 month 2 weeks ago #13172
by Joker
Hello,
in the manual of the ClassicNixie v6 is a value of 270K mentioned.
I found in my workshop 220k and 300k resistors.
Is the 270k a experience value?
I found on the Internet this values:
- Burningvoltage min. 65V, max. 90V
- Current 0,5 mA
With 170V, a resistor of 210K sould be enough or do i calulate with the wrong values?
I know the question is a bit boring, I was just wondering where the 270k came from
Thank you received: 40
1 month 2 weeks ago - 1 month 2 weeks ago #13173
by BS_Jim
The INS-1 is a slightly strange creature that doesn't always give reliable results. 270k is a good median value resistor to work in most cases. A 300k will give longer life, yet may suffer from flickering. A 220k will run the tube a little harder and probably be more reliable as far as not flickering, but it may cause a shorter lifetime of the tube. Your best bet is to try all three, one at a time, on a breadboard with your INS-1 tubes to find the highest value that doesn't flicker. I wouldn't use lower than a 200k unless you like changing tubes frequently.
Last edit: 1 month 2 weeks ago by
BS_Jim.
Joker
Builders Forum
Resistors for INS1
Time to create page: 0.086 seconds
