Builders Forum
Partial display of number
Thank you received: 0
9 months 1 week ago #11743
by TacticalTimbo
Really quite sad that my nixie clock has developed a fault. One of the NI-14 tubes has an issue displaying a complete ‘5’.
I bought the clock because I fell in love with the look, the moment I saw techmoan do a YouTube video on them, and mines been working fine for around 4 years.
I know nothing about soldering, and wondered how difficult it would be to replace the tube? Also I wanted to confirm if indeed it’s the tube, as I suspect, or an IC issue?
Thank you received: 172
9 months 1 week ago #11746
Ah yes, Techmoan. One of my favorite YouTubers!
The problem is almost definitely with the tube itself. If it were a driver IC problem, or insufficient high voltage, more than one tube would likely be affected. Your tube looks like it either has cathode poisoning or it's in the very early stages of losing its fill gas (neon). Losing gas is fatal. Cathode poisoning can be repaired if your clock has some sort of "tube healing" mode you can turn on to "bake out" the tube. depends on what clock you have.
Replacement tubes are still easy to find on eBay. Most listings call them IN-14 or NH-14 rather than NI-14. US$10 to 20 is a fair price for a single tube; cheaper if bought in larger lots. Look for tubes with long wires (proof the tube is not used) and avoid ones with short wires.
You say you know nothing about soldering, so I would say the replacement would be difficult. Removing the tube will be tricky because there are 13 wires to desolder. You have the choice of desoldering all 13 perfectly so the tube can be pulled out intact, or cutting the wires off flush with the tube's glass envelope and then removing the wires from the board one by one. Either way there is some risk of damaging the board with heat.
Having said that... with proper tools tube removal isn't too bad. I've successfully removed IN-14s using a Hakko 808 solder removal tool. With some skill and luck it can be done using either solder wick or a cheap "solder sucker" but that's a bit riskier.
Thank you received: 120
9 months 1 week ago #11749
by Ian
There is a burn mode, but it is to be used with caution. It can heal problems like this, but shouldn't really be used for extended periods or for anything other than correcting acute problems. Don't get into the habit of fixing things that aren't broken - it will only shorten the life of the tube if used without cause.
To get into "burn" mode:
Hold down the button for 10 seconds and then let go. "0" on the first digit should light up. Then you can cycle through all the digits using a short press until you get to the one you want to treat. Then leave it on that digit until the problem goes away. Don't leave the clock unattended while doing this and power off immediately if anything starts to smell.
You can come out of heal mode by pressing the button again for > 2 seconds,
While it looks like cathode poisoning, but it might be tube outgassing. The first one can be fixed, the second one will only get worse with time.
If you do need to change the tube, I would definitely advise you to snip all the wires close to the glass tube body and remove one by one. It's still tricky, and the hardest part without the proper tools is to get the holes clean enough to put a new tube in, even if you do get the old wires out. It's really a job for the correct tools.
9 months 6 days ago #11750
Ian, are you sure that clock is one of your kits? I couldn't figure out from the picture if it was or not.
9 months 6 days ago #11751
by Ian
Good point... No I can't tell.
Maybe everything I said is irrelevant.
9 months 6 days ago #11753
Or maybe not. We'll see what he has to say...
Builders Forum
Time to create page: 0.112 seconds
