Builders Forum
Inductor 100uH wrong size
Thank you received: 5
9 months 3 days ago #11567
by Hartmut E.
I accidentally bought the wrong size of Unshielded Wirewound DIP power Inductor 100uH I-shaped inductance.
Instead of 0912 (9 * 12mm) I bought 0608 (6 * 8mm), where is the difference because I can't do a technical comparison with my dealer
Thank you received: 120
9 months 3 days ago #11568
by Ian
6x8 doesn't have the current handling capacity. They can overheat quickly if you are using bright or large tubes.
If you can't use them in any other way, they are good for buck converters dropping 12V to 5V using an MC34063.
9 months 3 days ago #11570
by Ian
I don't think that is a good idea. Unless you can find the current rating for the part and you are not sure it is >=1A, I think it will fail quickly.
If you want to try anyway, leave the leads on the inductor quite long, so it will be easy to substitute. If the part is high quality, it might be OK.
Builders Forum
Time to create page: 0.096 seconds
