An SN-18 Clock in the Faberge style
11 months 2 weeks ago - 11 months 2 weeks ago #9951 by Scott
After purchasing one of Pete Virida's SN-18 kits and a few IN-18 tubes a case was needed to show it off.
Not something in the normal vein but something that would make it eye catching. The solution I came up with was an Ostrich egg shell.
The base of the clock was made from hard wood cut offs from some previous cases glued together and machined to give a nice round base. The brass work as from a pipe repair tube, some plumbing fittings and the addition of steam model maker's boiler banding. The buttons and LED shrouds were made from round brass bar. I added a second RGB in a perforated housing to the top of the shell. If you are wondering how it is fed a 3 mm brass tube containing the wiring was curved to the inside of the shell and runs from the clock board under the decking to the fitting for the RGB housing.
A plate is fitted to the rear for the cable inlets.
Turned out looking quite reasonable in the end!
Last edit: 11 months 2 weeks ago by Scott.
11 months 2 weeks ago #9952 by Ian
Nice work!
The Imagination and ingenuity of this crown never ceases to amaze me!
The following user(s) said Thank You: Scott
11 months 2 weeks ago #9955 by Ty_Eeberfest
I like it!! I somehow get an Art Deco feeling from it.
11 months 2 weeks ago #9959 by Scott
It as going to be very ornate originally but I gave up on that when trying to make filigree brass parts.
Art Deco a la Faberge then!
Time to create page: 0.172 seconds
