Options for connecting IN-1 tubes
5 years 7 months ago #7406 by JayRo72
Hi everyone. I built my first Nixie clock last year from one of the kits that Ian sells on eBay, using some IN-14 tubes I picked up. Being fairly new to electronics and drawing on my secondary school electronics module that was part of science class 30-something years ago (along with many questions answered by Ian) it was a steep learning curve, but I loved the experience!
I've just ordered a second kit, and have a set of IN-1 tubes that I'm going to use (once I figure out what to house them in), but I was just wondering if anyone had any ideas on the best way to attach the wires to those big chunky IN-1 pins? I saw this nice little socket that someone 3D printed while looking around. It seems fairly good. I'll need to find somewhere that will print them for me, but that's no bother...
github.com/hansj66/Nixie-socket-LC516--IN-1
Just wondered if anyone else had any ideas that might be a little simpler.
Thanks,
Jay
5 years 7 months ago #7409 by Ty_Eeberfest
I have dealt with this in the past by making boards very accurately laid out to match the tubes' pin pattern and then populating the boards with Mill-Max pins.
Here are a few pictures:
eeberfest.net/gallery.php?pagenr=1&set=clock
Here is some Mill-Max info.
This browser does not support PDFs. Please download the PDF to view it: Download PDF
I'm not so sure this is any simpler than the 3D printing option but it has worked nicely for me.
5 years 7 months ago #7410 by Ian
Hey Ty,
that's the thing that's been holding me back. The thought that the IN-1 tubes will need replacing at some point, and that this is not a simple "pull it out and push it back in again" operation. But if there are PCB mount pins available, then that changes everything. Do you happen to know the part number of what you ordered?
Did you also see the piece on back lighting with IN-1 tubes? I'm rather happy with the result of that...
5 years 7 months ago #7411 by Ian
Scratch the question about the part number, I see you did this for IN-18. (Although anyone building IN-18 stuff will probably want to know anyway).
5 years 7 months ago #7412 by Ty_Eeberfest
For IN-18 tubes I used Mill-Max 0344-2-19-01-34-27-10-0 which is stocked by Mouser as p/n 575-034420. US$55.00 per hundred in 2012. Before you order anything I strongly suggest you grab calipers and measure the real-world (don't trust data sheet) diameter and length of the pins and then look through the entire Mill-Max line for the best fit.
Don't get tempted to cheap out on this. There are certainly less costly socket pins to be had but you get what you pay for. Cheap pins tend to be stamped rather than machined. They contact the tube pin at one tiny point, whereas the good pins make contact over the entire length of the pin. At Nixie voltages this matters. It may work at first but it won't last, digits will quit working and you'll be chasing down burnt pins all the time.
Yeah this sounds like a pitch for Mill-Max products. I'm not affiliated in any way except that I've had real good results using their pins.
I haven't seen the backlighting article yet. But to be honest, I hate backlighting so I probably won't be thrilled :evil:
5 years 7 months ago - 5 years 7 months ago #7413 by Ian
Hi Jay,
there is another alternative that I nearly used once (or, more correctly, am meaning to use as soon as I do another IN-1 clock). There are certain Molex pins that fit IN-1 tube sockets. They look like these:
you can solder these, and then shrink a bit of heat shrink over it, and you can get a pretty good result. I think this covers off the most important requirements for making tubes exchangeable (but does not help for physical mounting question). I guess with a little bit of patented "Heath-Robinson Kludge Sauce" you could even mount these on a PCB and have that problems solved as well.
Last edit: 5 years 7 months ago by Ian.
Time to create page: 0.095 seconds
