Re: Is this IN-18 bad?
8 years 5 months ago #2995 by mathewbeall
Hi Folks,
I just got a batch of (6) IN-18 tubes and one of them displays this odd purple color only when the #1 segment is lit up. Is this something that will go away with time or should I have the person send me another IN-18 to replace this one?
Much Thanks,
Matt
8 years 5 months ago #2996 by GreyFox
Replied by GreyFox on topic Re: Is this IN-18 bad?
I have one like that - its a replacement tube and I have the blue dots on the #1 only. From what I understand it indicates that the tube is over driven. Or it has too much power driving the digit.
Let there be neon light!
8 years 5 months ago #2997 by mathewbeall
Replied by mathewbeall on topic Re: Is this IN-18 bad?
That is odd - it doesn't happen with any of my other tubes in that socket - which would lead me to believe that it isn't an issue with overdriving.
Matt
8 years 5 months ago #2998 by Nocrotec
Replied by Nocrotec on topic Re: Is this IN-18 bad?
Hi!
This is the well known Blue Spot problem!
Here is the description I sent to Brian today:
The blue spots are caused by the following circumstances:
If low voltage drivers are used, as example the 74141 drivers, the cold cathode voltage (non glowing cathode voltage) drops down to the clamping voltage of the output transistors (70-100 Volts).
In this state the mercury slightly breaks down, slightly ionizes, and little current flows from the anode, through all 9 non glowing cathodes through the Z-Diodes (Driver protection diodes) to ground. And that
inonized mercury can be seen as blue spots in the tube.
That's all.
How to avoid it?
Don't use any off cathode clamping voltage, but high voltage drivers.
And again, for the thousandth time: YOU CAN NOT DRIVE ALL IN-18 TUBES WITH 74141 DRIVERS!!!! SO DO NEVER USE THEM!
IF A BLUE SPOT APPEARS IN YOUR IN-18 TUBE THE CIRCUIT IS WRONG, NOT THE TUBE!
Look here:
www.nocrotec.com/shop/product_info.php/l...Dream-Nixie-Uhr.html
Dieter
If you are in a rush, walk slowly!
www.nocrotec.com
The following user(s) said Thank You: Stuckey
8 years 5 months ago #2999 by mathewbeall
Ahhhh - ok... I will try this tube in another clock I have that doesn't use those drivers to validate.... thanks for the information!
Matt
8 years 5 months ago #3001 by GreyFox
Bad circuit - Hmmmm my kit is one from tubehobby and the tube there that outgassed worked just fine. The replacement IN-18 has the blue dots for the #1 digit. So am I now faced with a bad circuit or a tube that is again out gassing?
Maybe I should switch kits ag go with a different setup.
Time to create page: 0.097 seconds
