Cleaning Tubes
  • Stuckey
  • Stuckey's Avatar Topic Author
  • Offline
  • Administrator
  • Administrator
  • Entrepreneur, Nerd, Caffeine addict
11 years 10 months ago - 11 years 10 months ago #252 by Stuckey
Cleaning Tubes was created by Stuckey
Hello -
What is the best way to clean a 40 year old tube without removing the markings stamped on it? I've used various cleaners on cheap tubes but I have a few large 7971's that I want to clean and leave the markings unharmed.
Suggestions?
www.ineedcaffeine.com
twitter.com/brianstuckey
Last edit: 11 years 10 months ago by Stuckey.
11 years 10 months ago #254 by bcoggs
Replied by bcoggs on topic Re: Cleaning Tubes
I am not the cleaning expert, but I would suggest first, very dilute dish washing liquid, failing that, dilute vinegar.
There's probably better net.wisdom. What happens when you search w/the terms restoration & 'vacuum tube' ?
11 years 10 months ago - 11 years 10 months ago #255 by Accutron
Replied by Accutron on topic Re: Cleaning Tubes
Don't get anything wet anywhere near the print. Many tube companies used water soluble paint, and Burroughs tubes do not have particularly resilient paint. When I clean a tube, I use a lightly damp cloth (water only) on the bulk of the tube, and I do not touch the print at all. If you need to clean near the print, use something delicate and precise to do the cleaning so you do not actually touch the print. We treat the print on all tubes as no-touchy.
A little-known fact, Burroughs had such a problem with the print rubbing off their beam switching tubes inside the box that later beam switching tube boxes have very tiny protruding nubs in the styrofoam insert, which hold the surface of the tube away from the foam by a fraction of a millimeter.
Micah Mabelitini
www.decadecounter.com/
Micah Mabelitini
Last edit: 11 years 10 months ago by Accutron.
11 years 10 months ago #260 by GreyFox
Replied by GreyFox on topic Re: Cleaning Tubes
How would you clean a tube with the red/orange paint on it like the East German Z574M tubes? I tried a dry microfiber cloth but it really didn't clean the tube off.
Let there be neon light!
  • Stuckey
  • Offline
  • Administrator
  • Administrator
11 years 10 months ago #263 by Stuckey
Replied by Stuckey on topic Re: Cleaning Tubes
I think I'm going to take everyone's advice here. I had some luck using a microfiber cloth and avoiding the markings altogether. I read a few suggestions on The Google where people had luck with Windex and CLR but I don't really want to try this method.
Regarding the orange coating - I know that warm water will remove that film :-/ Maybe an ultrasonic cleaner would work...but not many people have one sitting around.
Incidentally, if the coating does come off, you could always repaint it :) badnixie.com/Jeff_Thomas_NixiChrons.html
11 years 10 months ago #264 by Accutron
The red paint isn't exactly water soluble, but it will definitely peel off in chunks under warm water. I think if you're very gentle and avoid the yellow print, you should be able to clean it with a moist cloth. Don't apply too much pressure, use cold water, and don't use so much water in the cloth that it leaves standing beads on the tube. Isopropyl alcohol may also work, and evaporates faster than water. If the dirt requires CLR to remove, I'd just as soon leave the tube dirty.
I think an ultrasonic cleaner would completely destroy the print and possibly even break internal spot welds, but if somebody wants to donate the tube, I can drop it in my cleaner and see what happens.
Micah Mabelitini
Micah Mabelitini
Time to create page: 0.094 seconds
