First Build SNC46 preconstructed, muliple digits lighted up, on N1 3 not working
2 months 3 weeks ago - 2 months 3 weeks ago #13127 by IM_FBN
Hello Community,
i'm very new to nixie tubes and bought the SNC46 for in-12 tubes.
Howerver, i took the preconstructed board, did the few soldering components and pluged it in.
All tubes light up and change the digit every 2(?) seconds.
Unfortunatly none of the tubes show digit 1&2, socket N1 doesnt show digit 1,2,3 AND somehow all tubes show permanently digits 7, 8 and 9.
Has anyone experienced a similar problem?
Thanks for any help,
Sascha
Last edit: 2 months 3 weeks ago by IM_FBN.
2 months 3 weeks ago - 2 months 3 weeks ago #13128 by Ty_Eeberfest
Before anything you should test the tubes further. Pull out all tubes, then test them one at a time by plugging into the 1-second position. You will probably find that one tube has 7-8-9 shorted together and is affecting all tubes due to the nature of multiplexed displays.
Last edit: 2 months 3 weeks ago by Ty_Eeberfest.
2 months 3 weeks ago #13129 by IM_FBN
Im using the 4 digit variant, so there is no 'second' socket. All tubes show thes same behaviour if connectet to N4 (shows miniutes) without connecting any other sockets.
2 months 3 weeks ago #13130 by IM_FBN
I just tied it with the socket N4 one tube at a time.
The N4 socket would be the 1 to 9 minute digit, sice i have the 4 tube variant.
All tubes show the same behaviour as mentioned in the inital post. Its highly unliky that all the tubes are faulty.
2 months 3 weeks ago #13131 by Ty_Eeberfest
Okay, I agree that all tubes would not be faulty in the same way.
Next thing would be to very carefully inspect all pf your soldering, looking for solder bridges and also cold/fry joints.
Also verify that the K155ID1 chip is installed the right way around.
Is the display board connected to the clock board correctly? Do the RGB LEDs on the display board light up as expected?
2 months 3 weeks ago #13132 by Ty_Eeberfest
If you want, you could post high quality pictures of both sides of both boards. There's a chance I could see something that is causing the problem.
Time to create page: 0.094 seconds
