Modular clock issue
Modular clock issue
Thank you received: 1
1 year 1 month ago #12630
by roadrune
Hi.
My clock have been running perfectly for nearly a year, but yesterday when i came home from work, the time was way off, both hours, minutes and seconds.
I tried to connect to the wifi module but it wasnt online at all, so i did a factory reset, connected and set it up on my network.
Got to the settings page and changed the time server to Ian's new one, and that saved fine. However it will not update the time, and all other clock settings are available, but will not save. If i change anything and save it just refresh the page to default settings.
Any ideas?
Thank you received: 220
1 year 1 month ago #12632
Sounds like the WiFi module isn't talking to the clock anymore. A screenshot of the Summary web page would help us figure out what's doing on. Did you do any firmware updates recently?
1 year 1 month ago #12634
I'm a bit puzzled by the line:
Found I2C slave at 105
If there was a hardware failure preventing the WiFi module from talking to the clock I would expect that line to not be there at all. But if there is no communication problem at all it would look like:
Found I2C slave at (ping) 105
This implies a software issue, but you haven't changed the software and it was working fine until now. Odd.
Just to be sure I'm on the right track, go to the Settings page. make a change that should be immediately visible on the clock (maybe change LED effects?), save changes, and see if the change is seen on the clock. Let me know...
1 year 1 month ago #12635
by roadrune
No changes seems to reach the clock.
It scrolls back to date aswell now (probably default?) and the date shown is 1/3-17...
1 year 1 month ago #12637
Yes, those sound like defaults that were set when you did the factory reset. It's clear to me that the WiFi module and the clock are not communicating. What I don't know is why that is happening. At this point I'm hoping Ian has some suggestions...
Modular clock issue
Time to create page: 0.095 seconds
