Advanced programming question
1 month 1 week ago #12520 by tgibbs99
I want to customize the software on a modular nixie clock. I did purchase an AVRISP mk. II. I’m wondering if any one can point me to instructions to update the firmware using AVRISP through the ICSP, and not having to remove the at mega chip. Hopefully this can be done MacOS, but if A PC is required I could manage. I have populated the ICSP headers.
Thanks in advance.
Tim
1 month 1 week ago #12521 by Ian
Replied by Ian on topic Advanced programming question
I don't have any direct experience of the AVRISP, but if you have a 6 pin header on the programmer, it should not be a huge deal to start programming. On all modern boards (and I guess yours is up to date) there is a 6 pin ICSP header on the board. For the Modular it is between the Hours and Minutes tubes.
All you have to do it put a 2x3 header in it, and the rest should be fairly straightforward. Set the programmer type in the "tools" menu, and then you should be able to upload using the "sketch -> upload using programmer" option.
I find it helpful to turn on the verbose output for compiling and upload in the "File -> Preferences" menu.
Mac seems to work quite well with modern programmers.
If you want to flash a new chip, don't forget that you have to set the fuses! You don't need a boot loader.
1 month 1 week ago #12522 by Ian
Oh, and be super careful which way round you put the programming header in. There is no key on it, so it can go either way round.
The little "o" on the edge of the header silkscreen is pin 1.
Measure twice, cut once.
1 month 1 week ago #12523 by Ty_Eeberfest
I have an AVRISP Mk.2 I bought 10+ years ago and have used numerous times on Ian's modular clocks as well as on other projects. I still use it with various versions of Windoze and also on Ubuntu occasionally, but never tried MacOS. I can't add much to what Ian has already said but if you run into problems I might be able to help.
You'll have to pull out the 1h and 10m tubes to get the connector connected. The "key" on the AVRISP plug should point toward the separator LED / neon, not toward the Atmega chip. There's an LED inside the ISCP end of the AVRISP that lights green if all is good and flashes red if you have the connector on backwards. The board must be powered in order to get the green light.
I think I may have had to install libusb before the AVRISP would work, but that was a long time ago so my memory is imperfect!
1 month 1 week ago #12524 by Ian
That's cool that it tells you when you plug it in backwards - I suppose that is the advantage of the "real" unit. The ones I use work great, but there are zero bells and it doesn't whistle at all...
1 month 1 week ago #12525 by tgibbs99
I got it to work! Thanks guys!
Tim
Time to create page: 0.118 seconds
