Wifi IPV6
7 months 8 hours ago #12433 by _hagenaar
Wifi IPV6 was created by _hagenaar
Hello,
I just finished the construction of the clock. When I try to connect to the Nixie SSID I get a IP v6 address but not a v4 (even when i disable the ip v6 in the windows adapter settings) Is there a standard ip v6 address as well? or is there something else i can try?
7 months 8 hours ago #12434 by Ty_Eeberfest
Replied by Ty_Eeberfest on topic Wifi IPV6
MOVED to the kit support forum.
I have never seen this happen. Can you try connecting with a phone or other non-windows device to see what it does?
7 months 8 hours ago #12435 by _hagenaar
Replied by _hagenaar on topic Wifi IPV6
tried that as well. but i don't get the portal or a ipv4 address. Also 192.168.4.1 is not accessible
7 months 8 hours ago #12436 by _hagenaar
yes tried that as well. (iphone and ipad) than i get a ip v6 address as well. the portal doesn't work and the 192.168.4.1 isn't accessible either
7 months 8 hours ago #12437 by Ty_Eeberfest
I'm trying to reproduce the problem on one of my clocks. So far no luck.
When you try to connect from your phone what exactly happens? Does it ask for a password to join the network? Do you get a message popping up saying something like "Unable to connect to network NixieClockTimeModule"? You said it doesn't give you an IPv4 when using the phone but does it give you an IPv6?
7 months 7 hours ago #12438 by Ty_Eeberfest
Didn't see your second post. So it gives you an IPv6 when you use your iPhone? Could you maybe forcibly override it by going into the screen tha tshows you the IP adderss and change Configure IP to manual? Your IP - 192.168.4.2, Subnet - 255.255.255.0, Router IP - 192.168.4.1 The manually point Safari to 192.168.4.1
Time to create page: 0.095 seconds
