Firmware auto check?
Thank you received: 0
2 weeks 1 day ago #12423
by ebretteville
Hye everyone,
Tried to find my answer on the forum using the search filed with no luck.
I have a modular nixie clock with wifi module.
Is there any auto-check firmware updates implemented?If so we need to go the admin url? And then download the firmware on the website or the OTA means it checks and dolwload automatically the firmware and wait for an admin to apply it?
Thanks
Thank you received: 172
2 weeks 1 day ago #12427
The firmware does not check for or download firmware updates automatically. If you want to update you will need to get the firmware from the repo and install it yourself. Note that OTA is for updating the WiFi module firmware only (on all except Wemos clocks).
Most of us do not want our clocks doing things automatically without our permission, so that is one reason for no automatic updates. Also, unless you have a specific problem that can only be fixed by an update, there is not really much need to update a working clock,
2 weeks 1 day ago #12428
by ebretteville
Thanks @Ty_Eeberfest for this detailed answer.
Have you ever encountered a wifi module update? How does it looks like?
Thanks
2 weeks 1 day ago #12431
I'm not sure I understand your question but I will try to answer. Yes I have updated WiFi modules (and "down-dated" lol) when trying to find answers to peoples questions. With versions that support OTA it is simple and easy. With older versions it requires using ESP-01 programming hardware device.
The WiFi module firmware for the Modular has not changed very much over the years. The most important change is that newer versions let you use NTP time servers instead of depending on a "special" Olson time server.
The thing that makes updating WiFi firmware difficult is that you also (in most cases) also need to update the clock's firmware at the same time. If you have Arduino experience and have an UNO to use as a programming tool (or is you have "bare metal" Atmega experience and own an ICSP) it's not bad. If you have no experience it can get messy.
Time to create page: 0.117 seconds
