Nocrotec Sylvia Clock
By Dieter Wächter / Nocrotec
Price $299
http://nocrotec.com/start.php?navi=5&pid=14&gtxtid=100&lg=en
This clock is based on Vacuum Fluorescent Display tubes.  They are a seven-segment based display like most led clocks but these are quite a bit different.  For starters, this clock costs nearly 100x as much as your normal department store clock.  The digits have a beautiful cyan color and the design of the tube allows you to see the inner workings.  Image and brief description are from Nocrotec
FEATURES
- Digit height: 0.6″ (15mm)
- 12/24h mode
- Alarm clock
- Power down mode: tubes and supply can be totally switched off for a user programmed period in order to save energy and increase life expectancy of the tubes
- 12VDC input voltage
- Case made of massive cherry wood and shiny black anodized aluminum as used for high-end audio equipment.
Add comment
Security code
Refresh
We have 190 guests and 1 member online
in-17 and b7971 nixie clocks
