User Submtted
Reader Albert Y. from Seattle, Washington sent in his latest creation. It is a scope clock based off of the Thiem-Work components.  He was helped by Eric C. both in vision and execution.  It has a similar styling with the exposed CRT and the (what appears to be) aluminum base.  Nice work!
Albert Y. Thiem-Work Scope Clock
by Bob Coggeshall /
Mr. Coggeshall contacted my via the Facebook page to direct me to his website and I really wanted to show off his work.  (This is the first of two posts on his work.)
Mr. Coggeshall has developed a driver that can power up to seven B7971 tubes and is primarily driven by a computer.  One other feature that I have not seen elsewhere is that it establishes a serial connection over Bluetooth.  This enables the owner to place the device some distance from the computer without having to run cables.
Bluetooth B7971
from Cogwheel:
The Cogwheel model 301x  is a versatile Nixie tube clock driver board. Its features include
  • Drives tubes located on a separate board to accommodate a variety of tubes and custom enclosures.
  • Drive capability for up to 7 tubes with up to 14 cathodes each;
  • Supports classic “0 through 9” numeric tubes as well as large segmented alpha-numeric tubes such as the B7971.
  • Symbolic tubes and individual neon lights can also be driven.
  • Stable, modern design utilizing surface-mount components.
On board features include:
  • Flash-upgradeable processor (Microchip PIC16F877)
  • Non-volatile configuration memory
  • Adjustable high voltage generator fully controllable by processor.
  • Non-volatile clock chip (Dallas/Maxim DS1302) with capacitor backup for maintaining time for up to 12 hours across power outages.
  • RS232 Serial Interface – Can be interfaced to a GPS receiver, personal computer, or other device.
  • 1 pps (pulse per second) TTL level input for incrementing time from external source (GPS receiver or other equipment).
  • Cool-running 5 volt switching power regulator – Can supply up to 500ma of power to an external device such as a GPS receiver.
  • Infra-red receiver interfaced to a secondary processor (Microchip PIC12F675) for control
  • AC powerline frequency can be sampled by processor Runs on AC(9-12V) or DC(12-15V) power
Latest software release features include:
  • Complete Hours, Minutes, Seconds, Year, Month, Day timekeeping
  • Configuration via buttons, infra-red remote, or serial command interface
  • Configurable synchronization source - Non-volatile real-time clock, GPS, or serial
  • Configurable time increment source – Internal, 50/60 Hz AC Power, or 1 PPS input
  • Optional Daylight Saving Time Correction (North American rules)
  • Per-digit transition fading effect
  • Smooth transition between HHMMSS and YYMMDD displays
  • GPS – Display blinks if GPS does not have a fix
  • GMT offset to convert GPS time to local time
Be sure to check out his site for more information.
by Brad Lewis /
Brad Lewis Nixie Clock
One of our Facebook followers submitted this clock.  It is a Z660M based clock in a handsome black walnut case.  The aluminum bezels are custom machined for this clock.  Check out his site and build log for more info.  He has a few videos of the clock in action as well as photos of the internal workings.  (Incidentally, he also makes a nice Arduino Nixie Shield that's worth checking out.)
Tim Walker sent me a link to his great Scope/CRT clock build.  The internal mechanism is based off Thiem-Work kit.  He used a DG 7-16 display and the enclosure is made out of a clear plexiglass.  One other feature that he included that I haven't seen before is the inclusion of a motion sensor that only displays the time when motion is detected.  That has to be one of the most elegant burn-in protection mechanisms I've seen.
Scope Clock
Lastly, be sure to check out his neon work at  He has a lot of cool stuff to show off.
JSN Boot template designed by
