This tube is a pattern monoscope - it was used to generate numbers and geometric shapes.
Your bid is for a BRAND NEW, (new old stock), never used, ESE, model# ES 300, 4 digit timer which uses 4 RCA Numitron tubes to count minutes and seconds, up or down, to 100.00. There are 6 push buttons on the top front for Up / Down / Stop / Min / Sec / Reset.
The tubes are bright and light evenly. It is very hard to tell from my photos. It has been kept inside the protective plastic since the day it was purchased. It's in perfect, pristine condition! NOTE: I wil include a copy of the paperwork which includes description of components and features, operating instructions, circuit description, specifications, disassembly instructions, parts list, PCB layout drawing and schematic diagram.
eBay seller technolama is auctioning off an apparently unused GPSII nixie clock designed and built by Jeff Thomas. If you're a collector, this is an auction worth looking at.
NEW (NOS) NEVER USED MINT CONDITION GPSII GPS DISCIPLINED NIXIE CLOCK BY JEFF THOMAS. THIS CLOCK IS COMPLETELY ASSEMBLED AND READY FOR OPERATION. IT IS EXTREMELY ACCURATE BY USING THE TIME CODE DATA FROM ORBITING GPS SATELLITES. THE ONLY REQUIREMENTS ARE TO PLUG IN THE AC POWER SUPPLY AND GPS ANTENNA. THIS MODEL HAS BEEN OUT OF PRODUCTION FOR SEVERAL YEARS. JEFF THOMAS CLOCKS ARE KNOWN THE WORLD OVER AND ARE THE HIGHEST QUALITY NIXIE CLOCKS MADE. COMES COMPLETE WITH THE AC POWER SUPPLY, GPS "PUCK" STYLE ANTENNA, BAR MAGNET FOR ACTIVATION/SETTING OF ALL FEATURES, AND OPERATIONS MANUAL. THE CLOCK WILL BE CAREFULLY DOUBLE-BOX PACKED TO AVOID ANY DAMAGE IN TRANSIT. High bidder to cover shipping and insurance. Cashiers Check, PayPal, Personal/Business Check, Cash are all acceptable forms of remittance. Please allow 5 business days for Personal/Business Check processing. Thanx Much!
Technical Description :
THIS POLISH VERY RELIABLE CLOCK IS A PIECE OF SHORT SERIES NIXIE DEVICES MANUFACTURED IN THE SEVENTIES BY POLISH MERATRONIK (KNOWN AS PRODUCER MEASURE EQUIPMENT LIKE V543, V533, V541, V540 AND MORE). THE CLOCK IS IN WORKING CONDITION, 6 TUBES Z5660M ARE IN A VERY GOOD CONDITION WITHOUT SIGNS OF POISSONING. THE CLOCK HAS SOME LITTLE SCRATCHES ON CASE. CLOCK IS ORIGINALY PREPARED TO WORK WITH 110/220 V AC (external jumper), EXTERNAL KEEPING SETTINGS BATTERY (RANGE FROM 7 TO 10V DC), ADDITIONAL ELECTRONIC (g1,g2) CONNECTORS USED TO CONTROL OF EXTERNAL DEVICES . POWER CONSUMPTION 20VA.
ITEM CONDITION - USED. CLOCK IS SOLD AS-IS.
