Non-Tube Clocks: LED and other random clocks
Okay, tonight we have two new LED clocks to check out.  Sure, they're not nixie clocks but they are pretty cool and I think you'll love them.
First up is yanzeyuan's LED matrix clock.  This gadget is made up of 6 5x7 square led matrix displays.  Below is a quick video of it in use.  You can learn more about it in the forum, on his site, and you can purchase a kit for $99 on eBay.
{vimeo width="700" height="390"}27362023{/vimeo}
Next up is a large 4 digit 7-segment clock by forum member Digitalledclock. He posted a few cool photos in the forum and he will be selling these via eBay soon.  It is a nice clean design that I quite like.  Learn more in the forum and enjoy the photos below.  These sell for $199 on eBay (link coming soon).
LED Clock
LED Clock
$2.99 / iTunes Store
Okay, here is a bit of a departure from my normal reviews.  This is an iOS app for both the iPhone and iPod.  I haven't done a review like this before so hopefully someone finds it helpful.
{vimeo width="700" height="390"}25745170{/vimeo}
About two weeks ago the program creator, Kevin, emailed me and asked me to review his latest creation.  It is a nixie clock app and the reason that I really like this one is his attention to detail.  Below is his description:
From Kevin:
The graphics used for the clock were entirely hand-designed by myself in 3D. The tubes are a mix of features from a National NL-5025 and a RFT Z5660M with a whole bunch of inspiration from just about every other nixie tube I could get good reference images on. Every single component required to create a physically viable nixie tube is present and proper mechanically- the tubes are even accurately wired up, the cathodes are insulated from each other and the anode, etc. There is no reason why they wouldn't work if they were real (part of the reason why I created Numatron 2 was to see just how accurate I could make everything).
Likewise, the lighting effects required a fair bit of research into gas discharge tubes and the theory behind them. Most of my research eventually made its way into a set of 3D shaders that I used to create (what I believe to be) the first accurate 3D simulation of a volumetric discharge glow ever created.
From start to finish, the project took about 3 months. I refused to release the application until all of my (rather excessive) expectations were met. It wasn't good enough to "look like" a nixie tube. Numatron 2 had to be instantly recognizable as a nixie clock to anyone who was previously familiar with them, and in that regard, I believe I succeeded.
Photos:
Looking for a little Nixie Tube love on your work computer?  Dean sent me a link to his cool Yahoo! widget http://widgets.yahoo.com/widgets/steampunk-nixie-tube-clock.
From the website:
This is a simple Nixie Tube widget that displays a continuous time update on your desktop. It is based upon a Nixie vacuum tubes that were used as indicators in the 50/60s - 70s. The originals have a character of their own which this widget aims to replicate.
This widget acts as a simple clock upon your desktop and as an extra benefit it is also a moveable bit of eye-candy. It is a fully working widget. This version is beta so please no complaints on functionality - I will be adding more and fixing everything as time progresses.
LED Matrix DOTKLOK
Summary:
The Dotklok is an LED matrix (available in red or green) clock built and designed by Andrew O’Malley.  The clock is sold as a kit for $150 or fully assembled for $200.  Most importantly - this little thing rocks.
Video:
{vimeo width="700" height="390"}21922427{/vimeo}
Review:
Clearly, this is not a vacuum tube clock.  However, I was drawn to it because it is one of the few LED clocks that does not use 7 segment displays and clearly a lot of effort went in to designing the display patterns.  In fact, this clock offers over fourteen different animations ranging from Space Invaders to Pong.  Can’t decide on which one to use?  Let the clock pick a new one at random every day.
The clock itself features a dedicated real time clock that is able to keep the time and date accurate when the power fails.
The display is made up if a 24x16 pixel grid which works out to be 384 dots (or 0.000384 mega pixels @ 1 bpp).  The display is 3 ¾ inches wide by 2 ½ inches tall (10cm x 6.5cm).  When purchasing this clock, you can specify either a red or green matrix.
The display is made by Sure Electronics and even in the kit comes pre-assembled.  After looking at the surface mount parts - this is probably a very good thing!  For more detail, you can visit their website here: http://www.sureelectronics.net/goods.php?id=1136
The CPU is an ATmega328 running the famous Arduino boot loader.  That, coupled with the fact that you can bring your own FTDI cable means that this is defiantly a hacker-friendly device.  Andrew even includes the source code and schematics for download on his site.  All of this work is released under the Creative Commons ShareAlike license.
The enclosure is made up of two pieces of smoke colored acrylic separated by four metal standoffs.  There are four buttons which are drilled and mounted in to the front of the enclosure and appear to be very solidly constructed.  The electronics are mounted on two separate boards.  The back-most board houses the microprocessor for the device along with the RTC, the battery backup, programming interface, etc.  The front board is the display and it is connected by a ribbon cable.  The only slight complaint I have about the construction is that in order to push the front buttons you must grip the back of the unit as well; this is necessary to provide enough pressure to depress the button.  On its own this is not a bad thing but it does mean that fingerprints collect on the device because, if you're like me, you can't leave it alone.
Display Patters:
This clock has some really cool display effects, some that are more abstract, and some that are in between.  For example, the Pong clock is easy to read and functions well as both a clock and as eye candy.  On the other end of the spectrum is what I will call the "random dot fill" pattern.  The clock starts off (at midnight) with none of the LEDs illuminated and, at regular intervals, light up random LEDs until the display is solid green (immediately before it resets at midnight.)  The random dot fill effect is cool but it isn't possible to get an accurate time off of it.  In the middle is the percentage readout.  The clock displays the day as a percentage complete.  So, instead of noon, the clock shows that the day is 50.00% complete.  This too doesn't give a specific time reading but it is an interesting way to think about time.  The best thing that I've found is to set it on random and enjoy a new one every day.  Be sure to watch the last part of my video review to see these displays in action.
Features Summary:
  • 14 user-selectable time animations
  • 24/12 hour modes
  • "Random mode" can switch animations each day at midnight
  • 3.75" x 2.5" / 10cm x 6.5cm LED display
  • Dedicated real-time clock (RTC) chip keeps date/time with backup battery (included)
  • 4 button time/display interface + slide switch for mode selection
  • UL + CE universal power supply included
  • Open-source code can be modified by owners: eg. change the button functions and add new time animations
  • Easily re-programmable: software updates can be uploaded with a standard FTDI cable or USB-to-serial cable (not included)
  • Totally hackable: circuit board has prototype area and all unused Arduino pins are available; add more switches, buzzers, sensors!
UPDATE April 8 2011
Andrew added a new font to the software and sent me a photo of it.  Check it out:
Red Dotklok
Photos
LED Matrix DOTKLOK
LED Matrix DOTKLOK
LED Matrix DOTKLOK
LED Matrix DOTKLOK
LED Matrix DOTKLOK
LED Matrix DOTKLOK
LED Matrix DOTKLOK
LED Matrix DOTKLOK
LED Matrix DOTKLOK
LED Matrix DOTKLOK
LED Matrix DOTKLOK
LED Matrix DOTKLOK
Assembly Video by Jeff McCrum
{vimeo width="600" height="450"}21512693{/vimeo}
Final thoughts:
I really like this little gadget and I would recommend it - even if you can't assemble the kit yourself, the pre-assembled version is a polished product that shouldn't be hard for anyone to use.  I also want to thank Andrew for lending me one of his clocks to review - thank you!
As usual - you you have any questions, leave them in the comments and I'll do my best to answer them myself or find an answer for you!
