Full Thread Here: https://groups.google.com/group/neonixie-l/browse_thread/thread/7d000c18fea426cd?hl=en#
Note: DO NOT send orders to tubeclockdb.com!
From the thread:
Sorry for the delay on this folks. We have finally arrived at pricing  for the above and will be ready to ship in about 45 days (probably  less). Pricing is as follows:
Complete MOD-SIX_7971 Nixie Kit includes:
** 5 black solder mask modular PCB’s (3 dual tube boards, 1 CPU and 1 PS board)
** Pre-programmed CPU (see feature set below)
** All SMD and thru-hole components
**1.5 amp, 110 VAC-12VDC power supply
** Pre-sized copper tubing for colon towers
** Decorative precision CNC drilled and sanded 1/4” thick billet  aluminum base + all mounting hardware + screw-on heavy duty rubber  feet
** Custom-made and sized 1/4” thick acrylic top
** Assembly manual
$329 - PayPal only accepted.   (B7971 TUBES NOT INCLUDED)
$50 down payment required.
Assembler must be comfortable with SMD soldering! Add $75 for pre-  assembled clock.
Complete MOD-SIX_7971 Nixie Kit without Custom-Made Acrylic top
includes:
** Assembly manual
$267 - PayPal only accepted.   (B7971 TUBES NOT INCLUDED)
Assembler must be comfortable with SMD soldering! Add $75 for pre-assembled clock.
Please send me an email to order.
Feature Set
==Unique Right Angle Rotary Encoder User interface
==Auto Display dimming feature via photo sensor
==Adjustable DIM and Brightness levels with Adjustable Dimming  threshold
==QuickTime Set feature- quickly and easily set current time without entering config. mode
==19 Selectable FONTS
==Clock spells out the Month and Day of the week, also displays date and year
==Four user selectable colon modes- OFF, ON, BLINK, ALT, or RAILRD (railroad)
==TCXO time based
==Time On/Time Off sleep setting
==Velvety Smooth Digit Cross Fade feature with fade rate adjust.
==12/24 hour display mode selection
==Leading Zero Suppression selection
==Adjustable Pulse width Modulation setting value.
==Light Value Test Feature to determine optimal dimming point
==CW/CCW Rotary encoder direction selection
==Tube Timer
http://www.badnixie.com/The_%22Modular%22_Nixie.html
