499€ / Limited Edition (350 pieces)
Telefunken Nixie Clock
Here is a cool little TELEFUNKEN themed Nixie clock from Intron Electronic GMBH.  It is a 6 tube format but I can't quite tell what kinds of tubes they used from the photos.  I have contacted the manufacturer to learn more.
If someone here buys one, let me know.  I'd like to get your impressions of it (and maybe a few photos too...)
  • HH MM SS display
  • 12/24 hour mode
  • Adjustable display/tube brightness
  • Built in power supply for 100-240V 50/60 Hz
  • Battery backup
  • Dimensions: 325mm X 135mm X 126mm (W X H X D)
  • Mass: 2.2Kg
#1 Juergen Grau 2010-12-17 22:29
Hi @ all,
this clock was released some years before as an anniversary edition from Hughes&Kettner (a guitar amp manufacturer); see e.g.
And here's a picture with different sized tubes (Telefunken version)
With the original front cover you'll get this clock for "only" 299 EUR.
Best regards
Mr. Nixie
#2 Brian Stuckey 2010-12-17 22:37
@Juergen Grau - good find. I hadn't seen that one before. With the exception of the front cover, it looks identical.
#3 Juergen Grau 2010-12-17 22:44
I believe that H&K has produced a batch of 500 pcs in 2006 and now (after some years) Intron has bought up the remaining stock and only replaced the front cover for 200 EUR extra ;-o
#4 Guest 2010-12-19 03:34
I would really like to see some bigger tubes stuck in there! At least IN-18's for that price! Neat looking package though!
#5 Guest 2010-12-24 11:26
I believe these tubes are IN-14 (the larger ones) and IN-16 for the seconds.
#6 [email protected] 2012-05-12 18:46
I bought one yesterday! They are really nice, good looking clocks :-)
