by Tube Hobby
Price: TBD currently $300 on eBay
Tube Hobbie Nixie Clock
Tube Hobby has a handsome, fully assembled IN-18 clock with a wooden base for sale on eBay.  The current price is just under $300 with 4 days left on the auction.  Below are the specs provided in the auction but please visit the ebay link below to learn more.  They have provided links to the data sheets and the user manual at the bottom of the auction.
Technical data:
Software
  • Time display
    • 12-hour mode
    • 24-hour mode
    • Programmable leading zero suppression
    • Programmable DST correction (Including updated DST rules for USA and Canada in 2007)
  • Date display
    • DD/MM/YY mode
    • MM/DD/YY mode
    • Leap year correction
  • Programmable tubes shut-down during night time
  • Smooth crossfading with selectable deep
  • Three visual effects
  • Selectable automatic date show
  • Selectable refresh rate of tubes
  • Tube's lifetime counter (16-bit)
  • GPS time and date synchronization (GPS receiver is optional)
  • Selectable time-zone
  • Cathode poisoning prevention
Hardware
  • Sandwich type design
  • Microchip PIC16F876A main controller running at 20MHz
  • Real Time Clock with battery back-up (CR2032 Lithium battery)
  • Tube's drive mode: 3x2 multiplex (barely perceptible buzzing from tubes may be audible)
  • High voltage power supply with PWM control and software shut-down. Adjustable brightness
  • RS232 levels serial input
  • 2 pushbuttons
  • Power supply: 9-12V @ 800-2000mA DC; 5.5/2.1mm jack with positive inner
  • Incorrect polarity protection
  • High precision (10ppm) timebase XTAL (32.768KHz)
By Jeff Thomas / Resonant Instruments, LLC
Price: $299 / eBay
Jeff Thomas GPS Clock
Jeff Thomas has another great nixie clock for sale on eBay.  It is a $299 GPS 6-digit nixie clock that is encased in a clear arcrylic enclosure.  I have a Nixichron by him and it is easily one of the best designed clocks I own.  After reading the manual, this clock appears to have the same or a very similar setup.  The GPS feature is a very nice touch.  If you have ever had a power outage you will appreciate not having to reset this device.
From the auction:
GPSII features: Chronometer precision, using GPS.
  • Auto setting on powerup (no battery backup needed)
  • Menu items are permanently stored in EEROM.
  • 12 or 24 hours display.
  • Programmable display disable at night.
  • Adjustable display brightness level.
  • Safe 12vdc 300ma operation.
  • A professionally engineered product.
  • Variable Scrolling Information Display.
  • PM indicator for 12 hour display.
  • Digital Temperature sensor with quarter degree resolution.
  • Nine different Chime offerings (including Morse code)
  • Alarm clock feature.
  • Addressable colon indicators.
  • Leading zero blanking in 12hr display mode.
  • Automatic DST offset  -incl 2007 changes (USA, Europe, Australia, manual N and S hemisphere)
Now go buy it before I do!
via eBay
More information here
By Mikkel Holm Olsen / http://symlink.dk
Price: Not for sale
End View Nixie Clock
This clock is based on a Metric A/S frequency counter and apparently this unit as part of a remote display.  I contacted Mikkel to learn more about the original unit but sadly, I have not been able to find any of these on ebay, surplus sites, etc.  Regardless, I really liked the design and thought it was fitting to add to this site.  I really like his construction and of the home made clocks I've seen, the wiring and PCB on this is probably one of the cleanest.
If you happen to have one of these sitting around, be sure to let me know!
Be sure to check out his site for more information:  http://symlink.dk/projects/nixieclock/
Home Made Nixie Clock
Background:
Ever since I purchased my first numitron clock, I've been wanting to build a larger, 6 digit version using end view tubes.  I found the perfect kit by Richard White but the only problem was that I needed an enclosure.  While doing my normal research, I found the perfect host:
By Peter J. Jensen. LLC / tubeclock.com
Price: $210
Peter J Jensen Nixie Clock
I found this clock while looking for new content and not only is this one of the few clocks with end view IN-12 / ИH-12 nixies, they also have a great domain name.  I am partial to the 6 tube version but he also sells a 4 digit version as well.  I really like the simple design of the clock.  There is something oddly cool about the upside down "2" that is used for the 5 digit in these tubes.  I think this might be the next one to add to my collection!
While you're there, be sure to check out his IN-14 based clocks as well.
Description from Tubeclock.com:
Be mesmerized as you watch the seconds change on this 6 Tube clock.
Six IN12 Nixie tubes display either 12 or 24 hour (military) time. Measures 6 1/2 " wide, 3" tall and 1 3/4" deep. Weighs approx. 19 oz.
Fully assembled and ready to use.
Please note that this clock requires U.S./Canada standard wall power (120V AC, 60HZ).
All images and text used with permission and are property of Peter J. Jensen, LLC.
