By NixieKits.eu - 159 EUR (Kit, Tubes, Assembly)
+ 15.50 EUR (Internal Receiver)
+ 49.58 EUR (External GPS Transmitter)
It’s been a while since I’ve done a review so let’s jump right in. Today, we have the Laura nixie clock from NixieKits.eu. It has a fraternal twin brother named Lars, which is nearly identical in terms of features and electronics but uses a different enclosure and tube type. The Laura clock uses IN-2 tubes (small, round) while the Lars clock uses the rectangular IN-17 tubes. Both clocks feature a parsimonious enclosure design that focuses on the tubes and little else.
The review will focus on the Laura design but the basic features are common across both designs. Additionally, this review will include the Wireless GPS kit, which is available as an add-on for these clocks (and others).
The stand out feature of these clocks is the size. There are some comparably sized clocks on the market (Cogwheel’s IN-17x7, Nocrotec’s Little Blue Something) but there aren’t many. Most people want large IN-18, B7971, etc., tubes and that leaves room for smaller clocks in the market. Additionally, the fact that these can sit on your desk and not be the center of attention can be a large plus. Both clocks are USB powered and make a great companion to your workstation. (I keep the Laura immediately below my external monitor.)
IN-2 Nixie Clock
While we’re on the topic of design and size – this clock is unquestionably Jürgen’s design work. The Laura clock uses a similar structure to his original IN-12 design with the clear top, extruded aluminum sides, and decorative gold colored faceplate. The Lars design uses a solid black aluminum enclosure a copper-finished faceplate. (In fact, the Lars design looks like it would be perfect as part of a computer mod or on the dashboard of a car.)
Moving on to the tubes. Both clocks use petite tubes which have some advantages. They are generally easier to get replacements for and they cost less. I generally suggest getting replacement tubes asap after buying a clock and getting a spare set of 6 for either of these designs will be relatively easy on eBay.
The tubes themselves are similar in digit size with the obvious difference being the shape of the glass envelope. On the round tubes (IN-2), the numeral 5 is an upside down 2 like on many Russian tubes. The mesh is a little bit thicker than on most tubes but this doesn’t make them difficult to read. On IN-17’s, the numeral 5 is a distinct character. In both cases, the tubes suffer somewhat from a viewing angel problem – there are posts at the top and bottom of the tubes that hold the digits in place and they somewhat obstruct the display when you’re not looking at the tubes head-on. I can’t fault the clock design for this; all devices that use these tubes suffer from this design. The easy solution is to angle the display up (if it is on your desk) or mount it close to eye-height.
As far as tube brightness goes, I haven’t had any problems reading the tubes in a brightly lit room. They may not be a large as bright as IN-18’s, but these tubes don’t have any readability problems. (I can’t say the same for my LED clock, actually…)
The clocks feature a backlighting option that looks like an evolved option of Jürgen’s previous designs. The backlighting has always been a separate menu for the Nixie Kit designs back to the IV-12 Jenny VFD clock. I don’t think there are technical reasons for this but it does make manipulating the backlight color and display effects easier because it reduces the probability that you will accidentally set the time, alarm, etc.
IN-2 Nixie Clock
Color effects – this clock supports a few different color effects. The user can manually set the color via a special menu or it can rotate automatically. All of the options can be set via a dedicated menu accessible via the DST button. For example, you can have the clock display a constant cyan color or slowly rotate through all color options. Interestingly, the color can be set on an hourly basis. So, you can have orang at 12:00, blue at 13:00, green at 14:00 etc.
Tube display effects – of course a nixie clock wouldn’t be complete without some nifty display effects and these clocks are no different. This clock comes with a built in slot machine effect to prevent cathode poisoning. Additionally, users can enable/disable digit fading to smoothly transition between digits.
Tube saver mode – most new nixie clocks have the ability to turn off the display at a given time. The goal is to have the display off when you’re not in the room. But what about when you have the clock at your office? NixieKits.eu has a cool solution to this – you can specify a different off time for the weekend. In other words, you can have the clock on from 8AM-5PM M-F and off all weekend. This is a cool little feature that I don’t want to get lost in the review. Alternately, if you have the clock at home, you can have the clock on over the weekend as well (or even only during the weekend.)
Photos
IN-2 Nixie Clock
IN-2 Nixie Clock
IN-2 Nixie Clock
IN-2 Nixie Clock
IN-2 Nixie Clock
IN-2 Nixie Clock
IN-2 Nixie Clock
IN-2 Nixie Clock
IN-2 Nixie Clock
IN-2 Nixie Clock
IN-2 Nixie Clock
IN-2 Nixie Clock
Features
  • Hours, Minutes and Seconds display
  • 3 x 2 multiplex for less tube noise and higher brightness; based on the modern HV5812 Supertex high voltage driver
  • 12 or 24 hour modes
  • Uses a Quartz Crystal Oscillator as the timebase with adjustable accuracy
  • Programmable leading zero blanking
  • Date display in either DD.MM.YY or MM.DD.YY or YY.MM.DD format
  • Programmable date display each minute or selectable with a single button push
  • Scrolling display during fading-in the date or standard display change
  • Alarm with programmable snooze period
  • Optional DCF / WWVB / MSF / GPS sync. with status LED; prepared for fitting the ASK receiver module from the „Wireless GPS connection“
  • Dedicated DST button for easy switching between DST and standard time
  • Super Capacitor backup keeps time during power outages for more than 24 hours.
  • Simple time setting using two buttons
  • Five programmable column LED settings (Flashing AM/PM indication, illuminated AM/PM indication, both flashing, both on, both off)
  • Seconds can be reset to zero to precisely the set time
  • Programmable night mode - blanked or dimmed display to save tubes life or prevent sleep disturbance
  • Rear Indicator LEDs dim at night to prevent sleep disturbance
  • Weekday aware „Master Blank“ function to turn off the display on weekends or during working hours
  • Separate modes for column LEDs during night mode
  • Standard, fading or fading + scroll-back display modes as an eye-catcher
  • "Slot Machine" cathode poisoning prevention routine, disabled during night mode, selectable time
  • Programmable RGB tube lighting – select your favorite color palette
  • 729 colors possible. Have a different color of your choice every hour or auto-changing colors with variable speed
  • High efficiency „ultra cool“ HV converter, power consumption less than 2.5 VA even when RGB lighting is fully turned on.
  • Powered from a single USB outlet (from your PC or a cellphone charger)
  • All user preferences stored to non-volatile memory
By Re-electronics - 44,800 Yen
Written Review:
The very first thing that you notice when you look at this clock is its build quality. There are not many wood clocks on the market and this one probably has the best build quality of them all. The enclosure reviewed is made of maple but walnut is also an option. The sides are made from fours distinct pieces (as opposed to a hollowed out block), the top is another distinct piece and the bottom is capped with a metal plate. The top of the enclosure is a surprisingly hefty acrylic enclosure that sits in the beveled edge around the top of the clock.
On the front and sides of the clock are a few vent holes. These actually serve a purpose beyond decoration. The front vents conceal an IR receiver and the left side conceals an ambient light sensor. The back has two major cutouts. The first if for the USB power and the second is to allow access to the buttons mounted on the PCB. These are used to set the time and display effects.
The second thing that you notice about this clock is its size. It is one of the most petite 6 tube clocks that I have reviewed. Watch the video review for a comparison – this device is smaller than the Little Blue Something and is quite a but less voluminous than even a can of soda.
Powering the device is easy – it works from a standard USB connector. I’m a little amazed that the 500 mA that a port provides is sufficient to power 6 tubes, 4 neon indicators and all of the supporting circuitry but it works great.
The tubes are Burroughs B5870ST. These have a fine mesh and produce very crisp numbers. There are also four miniature neon bulbs that act as colon indicators for the tubes. Interestingly, these are mounted on small PCBs that were clearly designed for this purpose. I particularly like this attention to detail because it makes the entire device look more polished.
Display Effects
There are a few built in display effects to both prolong the tube life and to add eye candy. You can program the digits to fade between values. There are a few speeds available and they produce a nice smooth fade between numbers. There is also a shuffle effect. The shuffle effect cycles through the digits based on their position in the tube from back to front; the numbers do NOT count sequentially 1.2.3…etc. If the numbers were illuminated sequentially there would not be a smooth front to back motion on the display. Interestingly, the display effects are set on a mm/ss basis. In other words, the minutes can be fading while the seconds can use the shuffle effect.
Other Features
This device has a built in thermometer which can display both Celsius and Fahrenheit scales. The value can be displayed as frequently as once per minute to once per day.
There is a built in ambient light sensor. As the ambient light increases, so does the tube brightness. This allows you to preserver tube life by running the tubes at a lower current (brightness) during the evening automatically.
Lastly, this device can be controlled via remote control. I am unable to test this feature because the pre-production model I was shipped glitches when I tried to use it so I am unable to review this specific feature.
  • 5VUSB power
  • Auto Dimming brightness
  • ON/OFF setting
  • High accurate time control by RTC
  • Setting Backup by Super capacitor
  • Many effect
  • Cathode poisoning prevention
  • Using tube socket for nixie tube
  • Has fuse for safety
  • High efficiency HVPS
  • Has fuse in HVPS too
  • “:” type colons
  • Date showing
  • Temperature showing
  • control by IR remote controller
  • nixie check-up effect (count-up)
  • High quality tube used
  • One year Free warranty
  • Shuffle effect
  • Celsius,Fahrenheit show
  • YY/MM/DD,DD/MM/YY show
Photos:
6 digit wood nixie clock
  • Seller Contact: This email address is being protected from spambots. You need JavaScript enabled to view it.
  • http://kibanhonpo.shop-pro.jp/?pid=43079673
  • http://www.re-electronics.com
  • Manual (English)
  • Manual (Japanese)
Video Review:
Written Review:
This is the Little Blue Something in the Black Brilliance case from Nocrotec and NixieKitWorld.com . This clock is sold as a kit and this particular one features Burroughs B-5853 tubes with blue LED under lighting but other tubes and under lighting options are available as well. (You can see other variations of the same design here.)
The Burroughs tubes used in this device are some of my favorite. They are not nearly as large as an IN-18 but they are very legible with crisp edges around the numbers and a proper numeral 5. The tubes feature a fine mesh which is almost invisible from a few feet away and the envelope is flat at the top except for where the gas was evacuated. I’m not sure what the point is of forming such a nice top (as opposed to a rounded version) but does add a nice visual effect to the device.
The enclosure is a shiny black acrylic with four flat metal bolts on each corner. It is assembled in the same way that other Nocrotec enclosures are with each side fitting in to grooves in the base to form the shape. With that said, there are no lose pieces and the enclosure feels sturdy. It is not a kid’s toy, but it still feels solid.
The LED under lighting is the same blue led setup that Dieter uses for many of his projects. This contrasts nicely with the orange glow of the neon digits but the color is user selectable (at the time of assembly) and the green led lighting options appears quite nice as well.
Accuracy
The LBS setup actually has a few different options for maintaining an accurate count of the time. It supports DCF inputs (for users within Europe) and GPS (via a DCF converter). Both of these options are extra and do not ship with the device. The board can also accept a 1PPS input if you want to sync it to another source. Lastly, the device measures the line frequency and automatically compensates the crystal to ensure long-term stability.
Tube Life
The board supports a few different methods for prolonging the tube life. The user can set display brightness via the switches on the back and he can set auto off times via a jumper when assembling the clock. The board also supports an LDR which allows the device to automatically dim in proportion to the ambient light in the room. This has the advantage of being automatic and significantly increases the life of the tubes
Photos:
Little Blue Something Nixie Clock
  • Floor lighting with 2 LEDs per tube, this ensures a very balanced floor lighting
  • different colours available for the LED floor lighting
  • extremely high-definition glow of the digits
  • extremely high life expectancy of the tubes
  • Digit height: 13 mm (0.51")
  • matched, tested tubes (NOS = new old stock = old, unused stock tubes)
  • Black Brilliance Case
  • Dimensions: Width: 155 mm, depth: 65 mm, total height: 61 mm, case height: 32 mm
  • crossfade mode (digits fade from one number to the next)
  • dimmable tubes
  • spare tubes available (see above)
  • tubes can be switches off manually (Clock runs further meanwhile)
  • 12/24 hours mode in DCF77 or GPS mode
  • date display (can be switched off)
  • date display in arrangement: DD MM YY or MM DD YY
  • Night power down mode (tubes can be switched off at preset times by hardware)
  • supports DCF77 receiver
  • simple assembling
  • no SMD parts
  • PCB in "black surface" technology looks neutral in enclosures
  • high grade epoxy PCB
Other options
  • The board supports neon indicator bulbs that can both blink and indicate AM/PM
  • The device can drive a few different tube configurations. From the manual:
  • Mode 1: is six tubes 2x3 multiplexed mode normal Nixie tubes (default mode)
  • Mode 2: is four tubes 2x2 multiplexed mode using normal Nixie tubes
  • Mode 3: is four tubes using dual anode tubes 1x4 multiplexed mode
  • Mode 4: is two tube non multiplexed mode using normal Nixie tubes
  • Mode 5: for two B7971 or ZM1350 special alphanumeric tubes multiplex 1x32
Price (as of this writing)
  • 6x tubes 38.56 EUR
  • Clock Kit (electronics & case) 144 EUR
  • DCF77 Kit 22 EUR
Recently, Pete launched his new Nixie QTC format for mid sized tubes. Let's take a look at what he's got:
To begin, QTC stands for "quick tube change." The QTC design is an interesting clock kit with the ability to easily replace tubes that previously were hard wired (such as an IN-8-2, Z5070M, or ZM1210). He does this by putting them on a mini PCB with a connector on the back so the tubes can easily be swapped out. Nixie tubes do eventually wear out and this is an elegant way to replace them. One of the advantages of having all of the tubes on mini PCBs is that the main board can support multiple types of tubes with no configuration.
The nixies are drive in a multiplexed display mode. The tubes are driven in a 3x2 multiplex and generate little noise and no perceivable flicker.
This device also supports GPS synchronization making it one of the most affordable clocks with this option.
The following features are standard for the kit version:
  • 6 X (your choice) Nixie tubes, with 18mm digit height
  • 6 X Tube cell components for mounting the tubes
  • All transistors, resistors, capacitors, ICs, diodes
  • 2 X Neon bulbs for hours:minutes:seconds separators
  • Double sided, plated - through - hole PCB with red solder resist.
  • Fully pre-programmed PIC microcontroller, with socket
  • Piezo alarm sounder
  • RGB LED Tube Lighting Pack
Kit with IN-8-2 Tubes:
http://www.pvelectronics.co.uk/index.php?main_page=product_info&cPath=1&products_id=72
With IN-14 Tubes:
http://www.pvelectronics.co.uk/index.php?main_page=product_info&cPath=1&products_id=71
Aluminum case:
http://www.pvelectronics.co.uk/index.php?main_page=product_info&cPath=3_13&products_id=78
Other Features:
  • Date display in either DD.MM.YY or MM.DD.YY format
  • Scrolling display of date or standard display
  • Alarm, with programmable snooze period
  • Optional DCF / WWVB / MSF / GPS synchronisation with status indicator LED
  • Dedicated DST button to switch between DST and standard time
  • Supercapacitor backup. Keeps time during short power outages
  • Five programmable neon colon settings (Flashing AM/PM indication, illuminated AM/PM indication, both flashing, both on, both off)
  • Programmable night mode - blanked or dimmed display to save tubes or prevent sleep disturbance
  • Weekday aware ‘Master Blank’ function to turn off HV/ tubes on weekends or during working hours
  • Separate modes for colon neons during night mode
  • Standard, fading, or fading + scrollback display modes
  • ‘Slot Machine’ cathode poisoning prevention routine
  • Programmable RGB tube lighting – select YOUR favourite colour palette
  • 729 colours possible. Have a different colour of your choice every hour, or autochanging colours
  • Not AC frequency dependent – works in all countries
