PRISM PCB with SMD Push Button
2 weeks 4 days ago #11647 by Hartmut E.
I once thought about integrating an SMD push button directly onto the PCB.
What do you think?
2 weeks 3 days ago #11648 by Torsten Lang
Hi Hartmut,
does any part of the metal shell like the small tabs that fix this shell reach down to the PCB? If yes you better keep the space underneath the switch free from traces...
With best regards,
Torsten
2 weeks 3 days ago #11649 by Hartmut E.
Hi Torsten,
no the tabs are inside the plastic body and are not on the board. I'm still waiting for the delivery and want to remove the metal case
2 weeks 3 days ago #11650 by BS_Jim
Hi Hartmut,
I believe on the switches in your picture, the metal casing does contact the board underneath, where the sides are folded inwards. If they are the type I'm thinking of, the case can't be removed as the switch mechanism would fall out. However, a strategically placed piece of electrical tape on the board before mounting the switch would be enough to prevent any shorts.
2 weeks 3 days ago #11651 by Hartmut E.
Hi Jim,
thank you for the hint I will report as soon as the delivery has arrived.
2 weeks 2 days ago #11654 by judge
Personally I use through-hole buttons on the PCB so that I can remote them if I want to. Not so easy to remote a SMD button, plus I'm not sure how someone would access the button on a running clock.
Time to create page: 0.182 seconds
