USB Powered IV-11 Single Digit VFD Clock Online
6 years 1 month ago - 6 years 1 month ago #6001 by vfdclock
No eBay APP ID défined in Kunena configurationNo eBay APP ID défined in Kunena configuration
USB Powered IV-11 Single Digit VFD Clock with acrylic enclosure V1.0-WITH TUBE
Brand new,I designed and made it by myself.
Notice:
For home use only.
Specifications:
Tube Name: IV-11 (Made in the U.S.S.R.)
Tube Size:22.5mm(Dia.);
Tube Height:60mm(no including the legs);
Digit Height:21.0mm;
Digit Width:14.6mm;
Clock Supply: 5V DC via MINI-USB;
Working Current: <=250mA;
Clock Size:54mm(L)*46mm(W)*70mm(H)
PCB Size:44mm*36mm;
PCB Color:Black;
Weight:43g(with the tube);
The clock works with any standard USB supply,use only high-quality adapter!
1).5V Mini-USB powered,easy to be used. Can connect to your computer's USB plugs directly.
2).Support 12H or 24H display modes, Leading zero blanking is programmable.
3).Display date in all format: YY.MM.DD or DD.MM.YY or MM.DD.YY or even MM.YY.DD.
4).Support 3 different Effs:Normal/Fading/Cross Fading for displaying time.
5).High accuracy RTC inside,accuracy per month:+-13 secons max.
6).Simple setting by using 2 buttons only and supports IR remote control.
7).Three alarms with weekends ON/OFF support,can be controlled individually.
8).Three programmable Auto Power ON/OFF mode,can turn ON/OFF NIXIE tubes in any time you want.This function can save tubes life.
9).8-level adjustable VFD tube bright with Auto-brightness feature(its ability to adjust the tube brightness depending on the current environment).
10).Rechargeable Backup Battery or Farad capacitor keeps RTC runing during power outages.
11).Tri-colored RGB LED mounted under the NIXIE tube. This LED can display any color with a lot of pre-defined auto colour change effects.
12).Store user settings in non-volatile memory.
13).Beautiful CAD designed acrylic case made using a laser cutter makes the clock look beautiful. You can assamble/disassamble the case by using only 4 screws on the bottom of the case.The case also has 4 bumpers as feet on the bottom of the case in order to stop to prevent case's damage.
For video(s):
For more information visit:
vfdclock.jimdo.com
VFD/NIXIE/OLED DIY
VFDCLOCK.JIMDO.COM
Last edit: 6 years 1 month ago by vfdclock.
Time to create page: 0.133 seconds
