My new IV-11 6-tube clock std v1.0 has released
6 years 5 months ago #5878 by vfdclock
Buy from ebay or from vfdclock.jimdo.com
http://www.ebay.com/itm/131061906140
http://vfdclock.jimdo.com
Here are some pics,and
Video:
And The big SP version will coming soon.
IV-11 tube height 55mm, diameter 22.5mm, Digit height: 10.5 mm, base size: 220mm x 52mm x 70mm; Black PCB;
Temperature sensor is included.
Features
1).5V Micro-USB powered,easy to be used.Can connect to your computer's USB plugs directly.
2).6 brand new IV-11 tubes display Hours, Minutes and Seconds.
3).Support 12H or 24H display modes, can show "A/P" in 12H time format.Leading zero blanking is programmable.
4).Display date in all format: YY.MM.DD or DD.MM.YY or MM.DD.YY or even MM.YY.DD.
5).Support over 10 different Effs:Normal /Fading /Cross Fading /Sticky Fading /Flash /Loop num /Wipe num /Wipe UU /Wipe DD /Wipe UD /Wipe DU for VFD display.
6).Crystal oscillator as timebase with adjustable accuracy and integrated with temperature sensor DS18B20, supports software beased TCXO(Temperature Compensated Crystal Oscillators).
7).Simple settisng using 3 buttons and support IR remote control.
8).Three alarms with weekends ON/OFF support,can be controled individually.
9).Programmable Auto ON/OFF mode,can turn ON/OFF VFD tubes in any time you want.This function can save tubes life.
10).8-level adjustable VFD bright with Auto-brightness feature.
11).Display temperature data in °C or °F with adjustable accuracy.
12).Rechargeable Backup Battery keeps RTC runing during power outages for more than days when battery is fully charged.
13).Tri-colored RGB LED mounted under the each VFD Tube. Those LEDs can display any color with three different breathing speeds, and can be controlled individually with a lot of pre-defined auto colour change effects.LEDs' lighting is adjustable.
14).Static driving, no flash.The highest voltage it carrys is less than 25V DC, no danger.
15).Store user settings in non-volatile memory.
16).Support CC1101 wireless module as receiver(Optional,not included,for receiving time sync single and others ).
17).Beautiful CAD designed acrylic case made using a laser cutter makes the clock look beautiful. The top black acrylic board are replaceable.You can assamble the case by using only 5 screws on the bottom of the case and won't see any scrws on the top surface.The case also has 4 bumpers as feet on the bottom of the case in order to stop to prevent case's damage.
Video:
youtu.be/FJC6ncX2wIk
Other information:
Circuit and datasheet,visit: vfdclock.jimdo.com
Contains:
1. 1PCS fully assambled clock(with 6 IV-11 tubes,all installed in an acrylic case);
2. 1PCS about 100cm micro-USB cable;
3. 1PCS 5V 1A USB power adapter;
4. 1PCS IR remote controler;
Batteries not included!!!(We can't ship batteries in the mail package,so the IR batteries and(or) RTC battery may not be included,you need to prepare it by yourself.)
Please Note that I need about 3 working days for assembling it after payment is received.
Payment methods:
We ONLY accept PayPal on eBay selling, other payment is not acceptable.
Please PAY within 7 days, or we'll re-selling the item.
Shipping:
We ship to American/U.K./Australia only via ePacket Delivery from China with tracking number;
Shipping time:10-20 working days to American(normally), depends on the destination location;
We ship to your PAYPAL Verified Address only;
We do combine items to save on shipping costs when possible.
VFD/NIXIE/OLED DIY
VFDCLOCK.JIMDO.COM
Time to create page: 0.143 seconds
