Mosfet heat sink, grounding?
1 year 4 months ago #9938 by Malugalugalugalugaluga
Should the high voltage mosfet be fastened down, grounded or have a heat sink attached? Everything is assembled right but it doesn't turn on. All that's in the manual is just the mosfets not fastened down.
1 year 4 months ago #9942 by Ty_Eeberfest
No need to do anything with the MOSFET unless you really want to, It's fine just standing there on its pins. A heat sink isn't usually necessary but feel free to put one on if you want.
BUT - if you put a heatsink on either the MOSFET or the 7805 you absolutely must NOT create a connection between the metal tabs of the 2 parts!!!! Use separate heat sinks that don't touch each other, or use mica insulators between the tabs and the heat sink(s).
The following user(s) said Thank You: gerritv
Time to create page: 0.139 seconds
