Fried the Ardunino voltage regulator after connecting DS3231
2 weeks 2 hours ago #11665 by thecardella
Hi,
I'm back here on the forum to report something that happened to me: I got at the stage of having the tubes installed on the board (4 tubes) and I wanted to connect the RTC module as next step. So far the Arduino was in "test pattern" mode and LEDs and tubes were working as expected.
Lacking of female dupont connectors, I soldered the DS3231 directly to the 4 pins for the I2C bus (top left of the board). As soon as I connected the power to the board (12V in the PCB connector) I saw that for a second everything was on then everything went off and some smoke came out from below the PCB. I unplugged the power immediately and I started looking for burn stains. The PCB looks alright, hopefully I did not burn anything there. The Arduno as well but I see that the 7805 voltage regulator is outputting 8V instead of 5V so I guess that is the component that went to heaven.
With this post I just wanted to double check if I did something stupid, Has it happened already to anybody?
Thanks
2 weeks 12 minutes ago #11667 by thecardella
After searching around, I believe that the issue might be unrelated to the fact that it happened just after I connected the RTC module. I was wrong, the Arduino clone I am using uses the AMS1117 voltage regulator. I believe it just failed by itself.
I am going to try with a 9V power supply and a new Arduino board.
1 week 6 days ago #11668 by Ian
9V is the best choice in any case: The AMS1117 regulators in some clones just can't handle 12V and have a short and eventful life. :(
6 days 5 hours ago #11690 by thecardella
I have now replaced the Arduino and using a 9V power supply. Everything seems to be working fine. Nothing is getting hot on the PCB and on the Arduino.
Thanks!
5 days 22 hours ago #11691 by Ty_Eeberfest
Sounds good! Thanks for the follow-up.
Time to create page: 0.162 seconds
