FW update for Wifi
2 weeks 5 days ago #11495 by Kaštíl
FW update for Wifi was created by Kaštíl
Hello all,
i have problem flashing Wifi module esp8266., i have Clasic kit Rev4 with external wifi replacing RTC,
i'm new to programming IO, can someone send or refer me where i can download Libraries included in wifitimeprovider ino code?
I use Arduino IDE.
I was successful to flash Atmel IO with Arduino UNO, i have separate programmer for wifi module from ebay but when i try to compile WifiTimeProviderESP8266.ino it ask for *.h files
i have Wifimodule for Clock SW Version 4.8( 3-4year old i think) old Atmega died, i changed burned IRF740 and Atmel IO, clock works but need to update WIfi-module because time is not updating.
Sorry bad english not native speaker.
2 weeks 4 days ago #11496 by Ian
Replied by Ian on topic FW update for Wifi
Hi - please post the error message.
In general, you should find the links to the libs that are needed next to the imports like this:
#include <WiFiManager.h> // github.com/tzapu/WiFiManager (0.14.0)
#include <ArduinoJson.h> // github.com/bblanchon/ArduinoJson (5.13.2)
If I have missed something, please let me know.
Also it is important that you work from tag V56 at first. The head of the repository is experimental, and might not compile!
2 weeks 4 days ago #11498 by Kaštíl
Replied by Kaštíl on topic FW update for Wifi
sorry I em new to this
log is too long a paste only eng:
Alternatives for FS.h: []
ResolveLibrary(FS.h)
-> candidates: []
WifiTimeProviderESP8266:37:10: fatal error: FS.h: No such file or directory
#include <FS.h>
compilation terminated.
exit status 1
to witch direcrtory i need copy those files,
I have download v56 version.
what do i need to setup/install in Arduino IDE to flash ESP8266,
Programing Atmega SW was eazy only open .INO and flash, but i em lost with Wifi ESP8266
how to add wifimodule board tipe to arduino IDE?
2 weeks 4 days ago #11501 by Ian
That sounds like the board is not the right type. Please select the board type as "Generic ESP8266":
If you don't have this option, you need to install the board via the boards manager.
2 weeks 4 days ago #11504 by Kaštíl
Thank you for help, i was able to compile it,
now what parameters do i need to setup on board parameters before flashing
can it stay as it is on screenshot? or do i need change?
2 weeks 4 days ago #11508 by Ty_Eeberfest
Replied by Ty_Eeberfest on topic FW update for Wifi
The info is right there in the comments at the top of the source code. Here are the ones you need to change:
CPU Frequency: 160MHz
Flash Frequency: 80MHz
Flash size: 1M (64k SPIFFS)
Builtin LED: 1
Erase Flash: All flash contents
Time to create page: 0.235 seconds
