Modular Nixie Clock Construction Manual Rev3
11 months 4 weeks ago #10294 by Hartmut E.
Hi Ian,
I have 2 questions:
1. is the position C4 with the 220uF and 10 Volt OK?
2. After which Flassch Gin did you have the idea with the milled out WS2812?
It takes a little bit of sensitivity to carry the WS2812 into the tube plate.:) :)
11 months 4 weeks ago #10295 by Ian
Hi Marvin
C4 is on the regulated side of the low voltage: 10V is fine, the regulated voltage is 5V.
The reason for putting them in the board is very simple. If you have a failure, the WS2812B can be replaced without destroying the tube.
The trick is to take a small square file and very slightly file out the square hole if necessary. The problem is that the square holes are routed out with a round bit, and it leaves the hole a little tight. Two or three strokes in each corner of the hole is enough.
I see the results you have are perfect, but perhaps you had to squeeze the WS2812B a bit. There should be some spares just in case.
11 months 4 weeks ago #10296 by Hartmut E.
Hi Ian,
this I will try again to rework the radii of the opening of the WS2812B.
Thanks for the information.
Best regards
Hartmut
11 months 4 weeks ago #10297 by Ian
Usually one or two light strokes is each corner is enough.
11 months 4 weeks ago #10298 by Hartmut E.
I did a little post-processing with the knife. Once the tube plate and the WS2812B.
Everything is fine and the first clock is already working.
Time to create page: 0.199 seconds
