Problem with ESP01
1 year 4 months ago #9616 by BS_Jim
Problem with ESP01 was created by BS_Jim
I've flashed an ESP01 and an Atmega to v55 for a v1 clock. The problem is I can't log in to the ESP01. The AP shows up on my phone, but it is password locked and it won't let me in to set it up for my network. I've tried re-flashing it several times using different programming options with no success. Is there a default password?
Jim
1 year 4 months ago #9617 by Ty_Eeberfest
Replied by Ty_Eeberfest on topic Problem with ESP01
Try this (without the quotes of course) as a password:
"SetMeUp!"
The following user(s) said Thank You: BS_Jim
1 year 4 months ago #9619 by Ian
Replied by Ian on topic Problem with ESP01
Just to put a bit of explanation behind that:
From this repository:
https://bitbucket.org/isparkes/nixiefirmwarev1/src/master/
and specifically, this sketch:
https://bitbucket.org/isparkes/nixiefirmwarev1/src/master/WifiTimeProviderESP8266/WifiTimeProviderESP8266.ino
Looking at line 162:
connected = wifiManager.autoConnect("NixieClockTimeModule","SetMeUp!");
1 year 4 months ago #9620 by Ian
Also, at the top of the file, there should be the sort of current recommended flashing options:
Board: Generic ESP8266 Module,
    Crystal Frequency: 26MHz,
    Flash: 80MHz,
    CPU: 160MHz,
    Flash Mode: QIO,
    Upload speed: 115200,
    Flash size: 1M (64k SPIFFS),
    Reset method: ck, Disabled, none
    Erase Flash: All flash contents,
    Builtin LED: 1
but these seems to change with every new release of everything... :-/
Really important is the "CPU: 160MHz" one.
1 year 4 months ago #9622 by BS_Jim
Replied by BS_Jim on topic Problem with ESP01
Thanks guys. That did it.
Jim
Time to create page: 0.168 seconds
