V355 bug
V355 bug
Thank you received: 1
2 years 2 months ago #9103
by lays
when using V355 and the webpage, all settings are lost on the webpage each time you want to change something(settings are set), using an atmega with 353 does not have this behaviour.
Thank you received: 167
2 years 2 months ago #9107
by lays
Hi Ty,
Yes, i updated the esp and the atmega, reverting back to 353 solved the problem
Thank you received: 111
2 years 2 months ago #9110
by Ian
v355 is not compatible with v353, there was a change in the I2C protocal to let the MinDim setting to be managed.
If you go to v355 on the clock code, you need to go to v355 on the Wifi module code, and vice-versa!
2 years 2 months ago #9270
lays wrote: Hi Ty,
Just to follow up... I was able to reproduce the problem here with Rev.2 V.355 when I loaded it on my Modular clock and WiFi module. It's a legit bug, the source of the problem has been located, and Ian tells me he's fixed it and will make it available very soon. Not sure if it will still be called 355 or rolled to 356.
2 years 2 months ago #9274
by lays
thanks for coming back to this, i was doubting myself for a moment
V355 bug
