Clock hangs after 25 days
3 years 3 months ago #7511 by Ian
I finally found the problem that caused the clock display to get stuck after 25 days or so.
It was caused by the internal millis() counter overflowing.
V46 of the software solves it!
3 years 3 months ago #7512 by Stackerlee
Splendid!
So around 25 days it was?
Seems to fit my observations.
I see you've done numerous changes in the code.
Will take a look in a while.
3 years 3 months ago - 3 years 3 months ago #7519 by Ian
Replied by Ian on topic Clock hangs after 25 days
A quick explanation of the failure mode.
I was reading millis() as a signed long value, but really it is an unsigned value.
After 2^31 milliseconds (=24days 10.5 hours or so) it rolls over to -2^31, a large negative number.
There is a function which knows the end time of the "temporary display" mode (date, LDR reading etc) which is usually set for 5 seconds in the future when you press the button. This is initialised to 0 and then moves forward each time you use temporary display mode. When time moves on, the check "millis < tempdisplayend" becomes false and the display reverts to normal time mode.
When we roll over, millis suddenly becomes much smaller than tempdisplayend, so the display gets stuck in temp mode.
Changes:
all refrerences to time variables are now unsigned long
When we finish temp display mode, we set the tempdisplayend time to 0
I also made some little changes to the backlight cycling code to make the cycles give stronger primary shades.
Last edit: 3 years 3 months ago by Ian. Reason: clarity
3 years 2 weeks ago - 3 years 2 weeks ago #7740 by Ian
A quick update. We're better, but not good.
Now it hangs after 50 days. Back to the drawing board...
Last edit: 3 years 2 weeks ago by Ian.
2 years 9 months ago #7931 by konradp
Replied by konradp on topic Clock hangs after 25 days
Hi Ian,
Is this still a issue?, does it mean that all clocks will hang after 50 days, is there a fix in sight?
2 years 9 months ago #7945 by Ian
It should be solved in V48+
We used to set an "end time" of the date display by using millis() + displaytime * 1000, but now we just put the number of seconds to display for in a variable and count it down until it reaches 0.
Time to create page: 0.181 seconds
